Or connect with the current security (if you know the password), and change it to WPA.tweakinfreak said:If you've never connected before and there is no security?
S'ok I thought you were replying (against) to the guy abovetweakinfreak said:Exactly....
Sorry I took it the OP meant connect for the first time and had no networking capabilities?
casey said:Thanks for the suggestions. He is using it at the moment with no security, that's why I am concerned.
If I try to alter to WEP or WPA as it is, it immediately breaks the wireless connection without giving me a chance to enter a code No. so cannot get back in to set up security. That's why I suspected it needed a wired connection. I wondered if I could connect his router to my PC & set up WPA on the router and then go back to his and set up his PC. Would this work.
casey.
