Settings for an SSHD?
23 Nov 2007
Lancashire, UK
I'll be cloning my laptop HDD later over to a new SSHD. I've only run pure SSD's or HDD's in the past, never a hybrid. What's the best setup in terms of disabling/enabling Prefetch, TRIM, so on and so forth?
OS is Win 8.1 64bit.
Cheers!
trim will be enabled automatically
you need the sata ports in ahci mode,not sure how to do a reg tweak on win8 if originally installed in ide mode you'll need to do clean install
but pretty sure theres a work around
Just install it as you would a normal HDD, the solid state cache is handled by the software on the drive.
