Settings for tonight's super moon.
18 Oct 2002
Snipers hide
Hi there, I have an ancient Canon 350d, F4 100-300 Sigma DG HSM and Signa 1.4x APO converter. Could you please recommend some settings for me to try?
Thanks.
I'm late to the party here, but tripod is a necessity to get your ISO down to 100. I went for spot-metering and just used aperture priority, but triggered from my phone so I wasn't shaking the camera. Don't think it turned out too bad:
Supermoon
EDIT: Gear is Nikon D7200 with Sigma 150-600mm Contemporary.
Aim for foreground subject to establish scale to establish it as super moon else it's just another shot of the moon done a million times before.
Partial metering on your camera at 420mm will still meter sky as well so go manual. Start at around 1/100 f/11 ISO100 you won't be far off.
Manual focus with lens set to somewhere close to infinity mark on lens scale.
Cloudy for me last night and I was working at the optimal time to get a shot (ie when the moon was on the horizon). Hey ho.
Here's one from September last year's supermoon taken at sunrise, with a kestrel for company.
Kestrel by Andy Davis, on Flickr
1/100th imo isn't fast enough for the Moon - which is moving quickly.
Depends on effective focal length but I agree.
Spot metering works perfectly for the moon.
f/8 to get your lens optimally sharp ( if you have a faster prime then f/4.0 or so works).
Decent tripod, mirro-lock-up, remote/timer, delayed shutter.
I'm a beginner but like to run before I can walk. I've not been able to get remotely close to the detail of any of the above efforts. But I had my first attempt last night since there was a clear sky and full moon over my garden. I suppose it's 'ok'. I'm going to practise some more at the end of the week on a waning moon and hopefully no cloud cover. I've been told I can get better detail on waxing and waning rather than full moon.
Thanks EGuitarStar. I like your clouds over moon shot, very atmospheric.
I tried another moon shot last night, a half moon. I think it came out better than my first full moon attempt.
