Setup vigor 130 and archer ac2300 router to sky fibre help
24 Sep 2020
Hi guys looking for help to set up this combo on a sky fibre dsl internet
so far I have selected the draytek vigor 130 to bridge mode in settings
sky hub is a hub 2 (sr102) model which I have removed
connected to my archer router but not connecting any info would be great thanks
20 Oct 2008
Is it a router that's known to work with Sky?
Does it support Sky's DHCP option 61 authentication? A quick Google didn't find anything definitive that said it does. If it doesn't it just won't work and you'll have two options 1. return it 2. change ISPs.
13 Jul 2005
Norfolk, South Scotland
Can you connect your pc to the 130 directly to make sure bridge mode is working? Then look ar router
That will be relatively difficult because of option 61 with Sky. The modem just passes the data - it’s the client that passes on the credentials. And from the link that I posted the TP-Link routers in the UK already have a sky specific set of settings baked in.
29 May 2005
Bristol
i dont have sky so no clue on option 61 but can you not add username and password in windows to test bridge mode like other suppliers then?
