(*) Sexiest Case (*)
Pretty much any Lian Li case. Although I may be buying one of those nice RV02 Evolution Windowed cases in white as I am starting to like them. Or do I wait for the RV03 with the window on the correct side [/pigheadedness] but the window on it appears too small... ARGHH! However with the window on the *cough* correct side you get a better view of the CPU etc, but you loose the view of the bottom of the graphics card which is the nice looking bit, but the RV03 window also seems too small in my opinion, like to show of my gear myself!
I do also like the rugged-looking ones like the HAF, depends what mood I'm in really!
NZXT Lexa Blacline, with the RED Fans and LED Display.
Streamline, piano black finished, with a nice symmetrical curvature.
Bitfenix Collosus? You have to be kidding me, looks like something out of deadspace.
Exactly what i said when i first seen it, the storage lockers on dead space :D
It's not even out yet, but def one of the sexiest cases so far this year might even get one for my rebuild plans...
http://www.overclockers.co.uk/showproduct.php?prodid=CA-036-CS&groupid=701&catid=7&subcat=1489
I still think that Corsair dont quite understand what we like to show through a window panel. On the 800D they had it slightly too low so you had this bar across the window and the PSU showing a little with cables. On this one it looks like its too far down again as the PSU will be in full view but the heatsink not really shown. Does anyone see my point?
EDIT: Just to add, I personally think that a window panel should show the motherboard area only. So the GPU, CPU, RAM etc, the HDDs and PSU for example should be hidden.
Agree totaly
I think a decent psu, like the corsair which don't look to bad can look nice on show but not with the main window, i think a separate window placed correctly to show off the branding of the psu, not to big, around 10mm from the full height of the top and bottom of the psu and around the same length so as to show it off but hide the cables. could work well, obviously a problem if you have a papp one or one that looks papp so sensible solution is to make the window removable and supply a mesh insert, tastefully done i think it could be a real winner.
sexiest case around that is mine
no but really http://www.overclockers.co.uk/showproduct.php?prodid=CA-072-SV&groupid=701&catid=7&subcat=
Also supprised the older Coolermaster ATCS cases have not had a look in yet also the newer ATCS 840 (soon to be mine, well is mine but being modded and powdercoated at the min hehe)
the CM ATC 201 remains one of the best looking cases ever
but tbh while it looks nice on the outside internally its not one of the best and would be useless with modern high end gear
poor airflow, cant use long GPUs or tall heatsinks only 4 HDD bays etc
not a fan of the 840 tbh the TJ09 comes closes to the ATC 201 in looks
