SFF case w/Full height PCIe
23 Sep 2009
London
Hi I have a full height PCIe DVR Card used for CCTV which is currently in a massive 4U case and was wondering if there are any SFF pc cases which can take a full height PCIe card? Vertically or horizontally via a bridge?
MicroATX size would do, however I'd prefer a MiniITX or something as compact as possible, but anything that's smaller than my 4U case would be great!
Yeah, a lot of them can like the silverstone sugo range, lian li, coolermaster etc. The only ones that cant really are the streacom cases. I have a VERY slim height Hiper media chassis that mounts it sideways. You can get riser cards or flexible PCIe ribbon extenders.
Yeah I'd prefer the slim ones with a riser, i see plenty of cube cases but no slim/low height ones with risers. I can get riser adapters, but i havent seen a case which allows mounting a pcie x1 card horizontally.
Do you know any slim cases that can do just that?
That's perfect. Can any riser card be used or are there any specific ones, I didn't see one as an accessory
I would have thought it would be better to get a flexible pcie extender ribbon cable from the bay than a specific riser card. :)
If its a bit pricey i completely forgot that the Coolermaster Elite 120 advanced will fit full height cards. And less that £40..
