- 22 Jun 2018
- Doon the watah ... Scotland
A few years ago, we moved to a thick walled house, and since that time I've persevered with powerline adapters between to connect devices around the house. This has managed for the most part, but its struggled at times as it tops out about 3Mb/s, and will definitely struggle more as we are moving away from satellite TV and more to on demand / NAS sourced media.
So its time to wire up the house properly. Given the layout / design of the house, I reckon my best layout is to essentially have 2 main switches, one for each floor which will connect up the various devices including wifi access points ... something similar to this:
The link between the 2 switches is going to be a pain the hoop to run, and will involve a fair bit of work in terms of creating a hole between upstairs and downstairs in a cupboard. I'd like it to be a one-time install if possible. The run would be between 10 to 15m in length.
So I had thought that if I got 2x 1Gigabit switches with SFP ports and run a fibre cable between the 2 ... would that fibre cable likely be able to used for 10Gbit stuff if I were to upgrade the system later down the line ?
i.e. upgrade the switches, and the SFP modules, but leave the original fibre cable ?
( I cant really see me needing 10Gbe for a while though to be honest )
Code:
INTERNET <---> ISP MODEM/ROUTER <---> SWITCH <-------------> SWITCH
Downstairs Upstairs
Devices Devices
