SFTP Server Best Solution ?
30 Jun 2003
Watford
We are thinking of putting in an SFTP server in our organisation and just want to find out which is the most user friendly and easy to configure on Windows ?
Just to be clear, you want to do FTP over an SSH tunnel (SFTP), or FTP with SSL certificate (FTPS). I personally prefer FTPS and would look at Server 2008R2 with IIS, however if cost is an issue Filezilla server offers both IIRC or go down the Linux route.
What are you most comfortable with? Linux vs windows and what's the budget?
We are most comfortable with Windows as we don't run many Linux boxes. Also we need it to be SFTP as Message Broker only supports this protocol. In terms of budget we don't really have one but just need a good 3rd party solution that is easy to configure and set it up centrally so we can use any service to pump through to a central SFTP server.
