- 12 Sep 2008
Hi, just need some help here. I am no networking guru but im sure most of you guys are.
I have 2 PC's - an old crappy dell one with a wireless internet receiver which I use for browsing the net and a custom built PC (spec as in the sig below) with no net.
I have connected both PC's with one crossover network cable and have shared folders all working perfectly - however I am trying to share the internet connection but to no avail! I will try and provide as much information as I can to show you guys the settings and what I have tried and all that so you may know what my problem could be. Firstly here are the TCP/IP settings I have on both machines:
Dell PC
Custom PC
I have also enabled the setting to share the internet on the Dell PC
I have tried many different ports on both machines (eg. 192.168.0.60, 192.168.0.12) and have tried assigning the settings to automatic.
I have de-activated the windows firewall on both PC's and am running xp32 on both machines. I have had a shared internet working between these PC's once before but then I upgraded my motherboard on the custom PC from an Asus P5n-e SLI to an Abit IP35 and it no longer works. I have created new networks countless amounts of times with the windows network wizard and it still never seems to work for me. Also I am using ESET NOD32 as a virus protector.
Please, if anyone knows where I'm going wrong I would really appreciate the help!
Dell PC
Custom PC
I thought I wasnt supposed to have two things on the network having conflicting addresses. Do I have to restart before the changes take affect?
default gateway address not its ip address
