Sharing Files using Vista & Crysis help
28 Jun 2006
1. I have just changed over to Windows Vista Ultimate (from Windows XP Pro). Under Windows XP Pro, I shared files so I could stream them onto my Xbox. How do I do this with Vista? I have tried sharing the folder but the xbox doesn't pick up any shares :confused:
2. I have installed Crysis but it won't work with Vista but it worked fine with XP :confused:
Thanks for the help :)
open windows media player and enable media sharing - works for my PS3, would assume it will work for a 360.
any error messages etc. for crysis?
If you're talking about xbox media center for the original xbox, then some of the older versions are incompatible with Vista shares. Updating XBMC to a newer version should fix it.
I have updated XBMC now and its working - thanks for the help on that :)
In regards to Crysis, Vista says - APPCRASH and thats it.
Thank you :)
