Shaving Rash ><
11 Feb 2009
Barnsley, South Yorkshire
Okay, so everytime I wet shave with a razor around my neck I get an awfull rash, it's itchy, sensitive and rather red, it's really uncomfortable.
Is there anyway to combat this? I use a shaving gel for sensitive skin but it still rashes and it's really annoying ><
Clean your face well before and after. Use warm water to open your pours and cold to close them. Invest in a good aftershave balm for afterwards and rashes should become less of a problem.
If you're using cheap disposables, also try using something better.
/thread
What razor are you using?
I used to get quite bad shaving rash around my neck using a Gillette M3, moved to a Merkur last Christmas and haven't had a rash since.
This, plus get decent soap/cream and a good brush and check out the badgerandblade forums.
