She has arrived, but one thing?
28 Jan 2011
Hey guys,
received my Mac Pro today and man its gorgeous. The issue I'm having though, is in 1440p it won't let me change the refresh rate (my monitor supports up to 240Hz), but when I downscale to 1080p I can change it.
Now, is this the Mac Pro or the cable I'm using to test out. Surely the cable? unless MP doesn't support it.
FWIW I have the MP model with the dual D500 GPUs.
Cheers guys!
IIRC it was DisplayPort 1.2 on the 'trashcan' which means you will be limited to 144Hz @ 1440p due to bandwidth.
HDMI was 1.4, so 75Hz @ 1440p (i think).
Edit - I'm going off rusty memory as it's been a long time since i've touched a 'trashcan', so this could entirely be wrong :cry:
Are you using the HDMI port or one of the mini-DP ports? What cable are you using?
yeah HDMI to HDMI. Its a budget cable from the rainforest, so im assuming it might be that.
HDMI was 1.4.
Edit - I'm going off rusty memory as it's been a long time since i've touched a trashcan, so this could entirely be wrong :cry:
That would be fine for me, 144Hz. For what this will be used for. But defiantly struggling at 60Hz here atm! :(
ah yeah, you definitely won't be able to do 1440p @ 120hz+ over the HDMI 1.4 port, the mini-DP should work though (not 240, but 144 should be OK).
so even a good quality cable won't do 144Hz at 1440p?
What monitor are you using? As you need to be using DisplayPort.
Its a Samsung one, will check the model in a bit.
So what cable do I need to get this to work at 144Hz?
can you point me to the rainforest to see what cable I need?
No because OcUK sell display cables (although the range is admittedly pretty poor!)
im currently looking at DP to Mini DP?
is that correct?
Yes
Something like this, but ideally look for one labelled as DP 1.4, 4k@144hz or similar
My basket at OcUK:
Total: £8.69 (includes delivery: £3.99)​
thank you, and that would just plug into and 6 of the mini DP on the MP?
As far as I know (I'm not a Mac guy!)
Thunderbolt version 1 and 2 (as used by your Mac Pro) just use Mini displayport connectors - with thunderbolt 3 onwards they changed to USB-C connectors
Can't believe you actually did this.
You need your bump feeling :cry:
My bad. I do have the memory of a goldfish.
That is my excuse :p
Seriously though. Apologies.
