Shifters.. For children.
2 Sep 2008
Mynydd Isa
Hello
Im after some advice, my son has got the revo shifters on his bike 2x6. What quick shifters can I use? I was looking at the m310 but they are 3x6, is there anything I can use?
Thanks
Are you waiting twist/grip shifter, or trigger shifter?
Are the current ones broken?
You can buy them individually, but the front has to be 2 speed and the rear 6 speed of that's what he currently has, and stick to the same brand to avoid complications with cable pull ratios, so if shimano, get a shimano etc.
Quick Google and 2 speed front shifters seem quite rare, but 6 speed shimano rear shifters are easily getable. What's wrong with the current shifters?
You could use a 3 speed front shifter, and use the limit screws to stop it shifting into a non exististant 3rd ring and dropping the chain but that's a bit of a botch.
