Shoddy Workmanship?
11 Jan 2009
Kent UK & New Jersey USA
Spent an age putting my system together inly to get to the BIOS and the machine shuts down after 10s. (its also not picking up the HDD but that can wait.)
I could keep the system alive long enough to see the processor was at 85deg. I took the heat sink off and to my amazement it had not even touched the artic silver on the processor.
Close examination (as you can see from the pictures) shows that the mounting screws are not pushing the brackets down. they fit flush without the screws but once the screws go in they raise the metal high enough so there can never be a flush connection to the processor.
The screws go through a plate then into the heat sink, the holes in the heat sink dont have a thread, i assume this is why the screws are not pulling the bracket flush.
Anyhoos, have a look a the picture, Phil, I will call you in the morning. 2 days without a PC, Im going insane :)
The cooler is this model Noctua NH-U12P SE1366 (Socket LGA1366)
I have this cooler, must be a duff batch, the quality on my Noctua was way ahead of that I found on my TRUE. But I am sure they will honour a swap with that evidence.
yup just re checked instructions u need put the brackets on the other side of the heatsink. i installed this very same cpu cooler today
yeah they go the other side then when u screw them in they tighten on the thread in the heatsink il scan the instraction sheet if u like?
Ok so screw through the heat sink down onto the brackets I guess. Not getting out of bed, that's a job for the morning.
If it works which I am sure it will, any ideas why the he'd was not found ?
Welp. That indeed did sort it. The power of pictures huh? The drive was found this morning, i then rebooted with the Vista CD and its loading as we speak. Anyone know if there is a motherboard guide for the P6T? I'd like to know what settings to use, i have everything AUTO ATM
Oh and another question. How in gods name do i install my Fatality Card as the GFX card covers all the PCI slot.
I have my GFX card in the top blue PCI Express slot.
Dont understand TRUE . Sorry :(
TRUE = thermaltake ultra (120) extreme.
one of the best coolers on the market, i spent ages looking at different coolers and it came down to 2 the TRUE and the noctua, the TRUE was cheaper:)
but still good cooler, my temps idle at 35c'ish which i thought was a little high but then under load NEVER go above 47/50c
i stil bought the noctua vortex fan :D very quiet and pushes air nicely, thinking of maybe doing a push/pull with 2 of these babies!!!
