** SHORTAGE ON HIGH WATTAGE PSU's PERFECT FOR MINING (BITCOIN): NOT AT OcUK THOUGH!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
There is a mass shortage on PSU's over 850W at the moment, but OcUK has being working hard to secure as many brands as possible on high-wattage PSU's and here are the models we have in stock right now:-
Antec High Current Gamer 850W Modular '80 Plus Bronze' Power Supply (0-761345-06225-1) @ £125.99 inc VAT
Antec's HCG M power supplies are the perfect combination of power and efficiency. The HCG M features special heavy-duty High Current connectors and cabling that supply extreme levels of power, and superb efficiency thanks to 80 PLUS® BRONZE certification and Active PFC. HCG M's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. Highest-quality connectors, Japanese-brand capacitors, and a quiet 135 mm LED double ball bearing fan complete the package. CircuitShield™ makes the HCG-850M safe and reliable in any environment with its nine industrial-grade protections. If loads of power, High Current engineering and extreme efficiency are what you're after, the HCG M is the PSU for you.
Features:-
- 850W Continuous Power - Guaranteed 850W of Continuous Power from Antec
- 80 PLUS® BRONZE certified - Up to 88% efficient, to reduce your electricity bill
- AQ5 - Antec Quality 5 year warranty and lifetime global 24/7 support
- Dimensions: 86 x 150 x 170mm
- 16-pin Socket - Industry-leading 16-pin sockets double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future connector changes
- 135 mm LED DBB Silence - Whisper-quiet high-quality LED double ball bearing fan with long lifetime
- Thermal Manager - An advanced low voltage fan control for optimal heat & noise management
- High Current Rails - 2 +12V rails with high load capabilities ensure maximum CPU & GPU compatibility
- 98.8% +12V - Output for maximum CPU & GPU support
- Multi PCI-E - 4 PCI-E connectors for multiple GPU support
- NVIDIA SLI®-Ready & AMD Crossfire certified - Tested & certified by NVIDIA® for SLI® & AMD for Crossfire systems
- CircuitShield™ - Full suite of industrial grade protections:
- Over Current Protection (OCP),
- Over Voltage Protection (OVP),
- Under Voltage Protection (UVP),
- Short Circuit Protection (SCP),
- Over Power Protection (OPP),
- Over Temperature Protection (OTP) & Surge & Inrush Protection (SIP)
- Japanese Heavy-Duty Caps - High-performance Japanese capacitors ensure tightest DC stability and regulation
- Stealth Wires - All wires darkened for minimal visibility in chassis
- Connectors: 1 x 20+4pin / 1 x 4+4 ATX pin / 4 x 6+2 pin PCI-E / 9 x SATA / 6 x Molex / 1 x Floppy
Only £125.99 inc VAT.
ORDER NOW
Be Quiet Power Zone 850W '80 Plus Bronze' Fully Modular Power Supply @ £109.99 inc VAT
Important new product for be quiet! Very nice range of PSU featuring a fully modular cable design, Cool-Down period of 3 minutes so the fans continue after shutdown to ensure proper cooling of components and to reduce damage, new Silent Wings 135mm 6-pole quiet fan and a 5 year warranty.. not to mention the design is very nice indeed for a PSU and definitely sets it apart from the competition. The best bit is the price on these units are the lowest for ANY fully modular PSU range and also are the quietest..also 5yr warranty.
Features:-
- Massive 12V rail design is ideal for overclocking
- Full cable management supports maximum build flexibility
- COOL*OFF feature run fans for three minutes after system shutdown
- Connect up to three case fans for optimized system cooling
- Designed for powerful operation even at 50‹ C
- 135mm SilentWingsR fan with innovative 6-pole motor enables quiet operation
- 80PLUS Bronze efficiency (up to 90%)
- Up to six PCI express connectors (NVIDIA SLI, AMD CrossFireX)
- Compatible with Intel C6/C7
- Five-year warranty
- German product conception, design and quality control
Only £109.99 inc VAT.
ORDER NOW
Be Quiet PowerZone 1000W '80 Plus Bronze' Fully Modular Power Supply @ £149.99 inc VAT
Features:-
Only £149.99 inc VAT.
ORDER NOW
BeQuiet Dark Power Pro P10 850W '80Plus Platinium' Modular Power Supply @ £149.99 inc VAT
Dark Power Pro supplies are already renowned as the world’s quietest PSUs in the high performance category. The Dark Power Pro 10 850W model takes that a giant step further with an all-new design topology that delivers 80PLUS Platinum performance, the world’s highest energy efficiency certification. Add to that an unparalleled array of enhancements that augment this unit’s compatibility, convenience of use, reliability, and safety, and the result is simply a power supply without equal. Simply put, this is the highest-powered, most technologically-advanced power supply be quiet! has ever built.
- Virtually silent operation achieved through a broad array of meticulous optimizations, including use of be quiet!’s custom-designed 135mm SilentWings® fan
- SilentWings fan features airflow-optimized fan blades, fluid dynamic bearing with copper core and high quality IC motor controller for the quietest possible operation
- 80PLUS Platinum certification and up to 94% power conversion efficiency let you do more work with the same power and reduce your power bills
- 850 Watts of continuous power provide deep power reserves for demanding computing applications
- NVidia SLI and AMD CrossfireX multi-GPU certifications allow you to build intense Quad-GPU systems with utter confidence
- Cable management with extra long cable reach simplifies component installation and reduces annoying clutter, increasing airflow and improving cooling in even the largest PC cases
- Overclocking key allows switchover between quadruple independent +12V rail mode and high-performance single-rail operation
ORDER NOW
BeQuiet Dark Power Pro P10 1000W '80 Plus Gold' Modular Power Supply @ £199.99 inc VAT
Dark Power Pro supplies are already renowned as the world’s quietest PSUs in the high performance category. The Dark Power Pro 10 1000W model takes that a giant step further with an all-new design topology that delivers 80PLUS Gold performance, the world’s highest energy efficiency certification. Add to that an unparalleled array of enhancements that augment this unit’s compatibility, convenience of use, reliability, and safety, and the result is simply a power supply without equal. Simply put, this is the highest-powered, most technologically-advanced power supply be quiet! has ever built.
- 80PLUS Gold certification and up to 93% power conversion efficiency let you do more work with the same power and reduce your power bills
- 1000 Watts of continuous power provide deep power reserves for demanding computing applications
Only £199.99 inc VAT.
ORDER NOW
BeQuiet Dark Power Pro P10 1200W '80 Plus Gold' Modular Power Supply @ £239.99 inc VAT
Dark Power Pro supplies are already renowned as the world’s quietest PSUs in the high performance category. The Dark Power Pro 10 1200W model takes that a giant step further with an all-new design topology that delivers 80PLUS Gold performance, the world’s highest energy efficiency certification. Add to that an unparalleled array of enhancements that augment this unit’s compatibility, convenience of use, reliability, and safety, and the result is simply a power supply without equal. Simply put, this is the highest-powered, most technologically-advanced power supply be quiet! has ever built.
- 1200 Watts of continuous power provide deep power reserves for demanding computing applications
Only £239.99 inc VAT.
ORDER NOW
Corsair RM Series RM 850 '80+ Gold' 850W Power Supply (CP-9020056-UK) @ £119.99 inc VAT
Corsair RM Series power supplies are fully modular and optimized for silence and high efficiency. Zero RPM Fan Mode means that the fan doesn’t even spin until the power supply is under heavy load, and the fan is custom-designed for low noise operation even at high loads. 80 PLUS Gold rated efficiency saves you money on your power bill, and the flat black cables are fully modular, so you can enjoy fast, neat builds. And, like all Corsair power supplies, RM Series is built with high-quality components and is guaranteed to deliver clean, stable, continuous power. Connect it to your Corsair Link system and you can even monitor fan speed and +12V current directly from your desktop (additional cable required for 450W-850W units).
Product features:
- Optimized for Silence: The components used to manufacture the RM Series are manufactured specifically for excellent performance and low audible noise.
- 80 PLUS Gold-certified Efficiency: Highly efficient RM Series power supplies produce less heat and have lower operating costs.
- Flat black, Low-Profile Modular Cables: You can use only the cables you need, and leave the rest in the box for fast, easy, and great-looking builds.
- Reliable, Continuous Power Delivery: Corsair uses high-quality internal components, and RM Series power supplies are guaranteed to deliver clean, stable, continuous power.
- Corsair Link Compatible: RM Series power supplies connect to Corsair Link software for real-time monitoring of fan speed and power delivery directly from your desktop. Additional hardware required for 450W-850W units.
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation Intel® Core™ processor Ready (Intel Haswell and Z78 motherboards)
- 80PLUS Gold certified, delivering over 92% energy efficiency at real world load conditions.
- The completely modular cable system allows you to use only the cables you need.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis.
- High-quality capacitors provide uncompromised performance and reliability.
- A five year warranty and lifetime access to Corsair’s legendary technical support and customer service.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- 135MM NR135L Noise reducing fan. MTBF: 100,000 Hours
- Universal AC input from 100~240V.
- Multi-GPU Ready
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, C TUV US, RCM, TUV, CB, CCC, BSMI, GOST, ROHS, WEEE, ROHS, KC
Only £119.99 inc VAT.
ORDER NOW
Corsair Professional Series AX 860W '80 Plus Platinum' Modular Power Supply (CP-9020044-UK) @ £167.99 inc VAT
The Corsair AX860 power supply runs quieter, generates minimal excess heat and it’s earned the 80 Plus® Platinum seal of approval, your guarantee that you’re making the right choice for smart, efficient power delivery. Because the AX860 is so efficient it operates without the fan even spinning at low and moderate loads.
All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow.
Built with High-quality 105C capacitors and upgraded components the AX860 is rated to run at 50°C and provide rock solid power throughout its seven year warranty.
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
- Silent at low to moderate load due to high efficiency and zero RPM fanless mode. Ultra quiet at high loads with 120mm dual-ball bearing fan.
- 80PLUS Platinum certified, delivering over 92% energy efficiency at real world load conditions.
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components.
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
- High-quality Japanese capacitors provide uncompromised performance and reliability.
- The completely modular cable system allows you to use only the cables you need. Power supply upgrade and replacement is easy, as the cables only need to be disconnected at the power supply.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer¡¦s chassis.
- A Seven year warranty and lifetime access to Corsair¡¦s legendary technical support and customer service.
- Safety Approvals: cTUVs, TUV, CB, CE, FCC, CCC, RCM, GOST-R, KC, IRAM, BSMI.
Only £167.99 inc VAT.
ORDER NOW
Corsair AX860i Digital ATX '80 Plus Platinum' Modular Power Supply (CP-9020037-UK) @ £191.99 inc VAT
The fully modular Corsair AX860i uses a Digital Signal Processor (DSP) for tighter voltage regulation, which improves overall system stability, and increases performance to 80 PLUS® Platinum levels. Built-in Corsair Link™ gives you unprecedented monitoring and control. Upgrading to digital provides increased efficiency. The AX860i is certified 80 PLUS® Platinum, which results in lower heat generation and a quieter fan profile. The AX860i is so efficient that the 120mm fan doesn’t even spin at low loads for completely noiseless power delivery. The built-in Corsair Link™ functionality allows you to know how well your AX860i is working at any given moment and lets you quickly tweak its performance. Server-inspired diagnostic tools monitor real-time efficiency, power usage, configurable over-current protection points and fan profiles.
Only £191.99 inc VAT.
ORDER NOW
EVGA SuperNova 1000W '80 Plus Platinum' Modular Power Supply (220-P2-1000-XR) @ £167.99 inc VAT
EVGA adds a platinum series power supply to its full line with the SuperNOVA 1000 P2. This Power supply is 80 PLUS Platinum rated with an efficiency of 92% under typical loads. The new ECO Thermal Control Fan System offers Fan RPM modes to provide zero fan noise during low load operations. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. Backed by a 10 year warranty, gain peace of mind from the heart of your system and power up with the EVGA SuperNOVA 1000 P2!
Features:-
- Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
- 80 PLUS Gold certified, with up to 90% efficiency under typical loads
- Highest quality Japanese brand capacitors ensure long-term reliability
- Fully Modular to reduce clutter and improve airflow
- NVIDIA SLI Certified
- Sanyo Denki Ball Bearing fan for exceptional reliability and quiet operation
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
ORDER NOW
Seasonic G series 750w '80 Plus Gold' Modular Power Supply @ £99.95 inc VAT
For the ultimate in low wattage, high quality PSU needs comes the Seasonic G Series PSU with 360 / 450 / 550 / 650 and 750w options these units are perfect for any HTPC or mid range gaming system.
- 80 Plug Gold Certified
- DC to DC Converter Design
- Tight Voltage Regulations (±3%)
- Smart and Silent Fan Control
- High Reliable Aluminum Electrolytic Capacitors
- Conductive Polymer Aluminum Solid Capacitors
- Detachable Modular Cables
- High Current Gold Plated Terminals
- 12cm Ball Bearing Cooling Fan
- Ultra Ventilation (honeycomb structure)
- Mulit GPU Technology Support
- Universale AC Input
- 5 Year Warranty
Only £99.95 inc VAT.
ORDER NOW
Seasonic X-Series 850w '80 Plus Gold' Modular Power Supply @ £149.99 inc VAT
The very first full modular multi-output ATX, high-wattage power supply that has ever obtained the 80PLUS® Gold certification is introduced by Seasonic, this coveted power supply is named “X” and is offered in 560W versions.
Featuring a patent pending design of “DC Connector Module with Integrated VRM”, the X Series is set to achieve both near-perfect DC to DC conversion and fully modularized design without compromising efficiency. After a long wait, finally there is a product that delivers the complete package, ultra-high efficiency, greatly improved dynamic response, and customizable cable arrangement that is tailored to meet any individual’s needs.
The X Series adopts a clever “Hybrid Silent Fan Control” design, which offers three distinct operation modes, fanless mode, silent mode, and cooling mode. The X automatically adjusts fan mode and speed according to the ambient temperature level. This brand new design not only optimizes heat dissipation, but also prolongs lifespan of the system by reducing unnecessary fan rotation. To make the X Series even more robust and exciting, Seasonic offers Sanyo Denki San Ace Silent Fan on X, the best fan there is in the industry.
- 80PLUS® Gold Certified Super High Efficiency
- Full Modular Cabling Design
- Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
- Seasonic Hybrid Silent Fan Control
- Sanyo Denki San Ace Silent Fan
- Highly Reliable Japanese Brand Capacitors
- Tight Voltage Regulation [±3%]
- Active Power Factor Correction [99% PF Typical]
- High +12V Output
- Dual Sided PCB Layout
- Ultra Ventilation [Honeycomb Structure]
- Multi-GPU Technologies Supported
- All-in-One DC Cabling Design
- Easy Swap Connector
- Universal AC Input [Full Range]
- 5 Years Warranty
ORDER NOW
Seasonic X-Series 1050w '80 Plus Gold' Modular Power Supply @ £179.99 inc VAT
Common to all X-Series power supplies, the new X-1050 and X-1250 feature the unique integrated DC connector panel with onboard VRM (Voltage Regulator Module) that enables not only near perfect D-to-D conversion with reduction of current loss / impedance and increase of efficiency but also a fully modular DC cabling that enables maximum flexibility of integration and forward compatibility.
An industry first, advanced 3 phased (Fanless, Silent and Cooling Mode) thermal control balances between silence and cooling. In addition, for X-1050 & 1250 a selector switch is provided to allow you to select between the Seasonic S2FC control, without fanless mode or the S3FC fan control, with fanless mode.
The world-renowned Sanyo Denki Ball bearing fans are made of the highest quality components to ensure maximum quality and performance. The use of spoon shaped high-density plastic fan blades with smoothed leading edges, strict tolerance ball bearings and precision copper axel are just some features to ensure ultra-low noise performance and quality. In addition, the fan uses 3 balancing points, instead of the industry standard of 2 points, to ensure perfect balance and rotation. The Sanyo Denki fan is a perfect match to the class leading Sea Sonic Hybrid Silent Fan control for the absolute top performance of the industry.
- High +12V Output
- 5 Years Warranty
Only £179.99 inc VAT.
ORDER NOW
Seasonic X-Series 1250w '80 Plus Gold' Modular Power Supply @ £209.99 inc VAT
- High +12V Output
- 5 Years Warranty
Only £209.99 inc VAT.
ORDER NOW
Silverstone SST-ZM1350 Zeus Power Supply - 1300W @ £287.99 inc VAT
After a four year hiatus, SilverStone’s top of the line power supply series, Zeus, has finally returned. The all new Zeus ZM1350 retains excellent characteristics of its predecessors with continuous output of 1350W (1500W peak) rated for 24/7 operating at 50°C, ±1% regulation for exceptional stability, and careful selection of premium industrial grade components. Other aspects such as efficiency, modular cabling compatible with other SilverStone PSUs, and adjustable switches for multi/single rail, voltage tweak, and fan control are vastly improved to make this the most thought-after power supply for elites among IT professionals, PC power users, and overclockers.
Features:-
- 1350W continuous output and 1500W peak power at 50°C (60? with 1080W continuous)
- Low ripple & noise with strict ±1% voltage regulation
- Patented six / single +12V rails adjustable switch
- User-accessible +3.3V / +5V / +12V rails voltage adjustment pots
- 80 PLUS Silver certification with 80 PLUS Gold level efficiency at 230Vac
- Class-leading +12V rails combined loading up to 105A
- Industrial grade components
- Advanced 100% full cable management
- Long life dual ball bearing 80mm fan with speed control switch
Specification:-
- Model No. SST-ZM1350
- Max. DC Output 1350W (Peak 1500W)
- Color Black (scratch resistant and lead-free paint)
- Cooling System Single long life dual ball bearing 80mm fan
- Noise Level 20dBA-40dBA
- Dimension 150 mm (W) x 86 mm (H) x 230 mm (D)
- Weight 4.5kg
- Certification 80 PLUS Silver
Protection
- No Load Protection
Connectors
- 1 x 24 / 20-Pin motherboard connector(500mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(700mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(500mm)
- 6 x 8 / 6-Pin PCIE connector(500mm)
- 2 x 8 / 6-Pin PCIE connector(500mm / 150mm)
- 16 x SATA connector (500mm / 150mm / 150mm / 150mm)
- 6 x 4-Pin Peripheral connector (500mm / 150mm / 150mm)
- 2 x 4-Pin Floppy connector (500mm / 150mm / 150mm / 150mm)
Only £287.99 inc VAT.
ORDER NOW
Silverstone Strider Series 1500 Watt (SST-ST1500) @ £233.99 inc VAT
Exorbitantly powerful 1,500 watt power supply with eight 12V rails, cable management and 80Plus Silver Certificate
Specification:-
- Dimensions: 150 x 86 x 220 mm
- Construction: Modular
- Weight: 4,2 kg
- Fan: 135 mm (19 - 34 dB (A))
- Efficiency: 88 - 92%, including 80Plus Silver Certificate
- Form Factor: ATX12V 2.3
- Life Expectancy: 100,000 h
- Active PFC (> 0.95)
Total power: 1500 W
- 3.3V: 40A
- 5V: 40A
- 3.3V +5 V Combined: 280W
- 12V1: 25A
- 12V2: 25A
- 12V3: 25A
- 12V4: 25A
- 12V5: 25A
- 12V6: 25A
- 12V7: 25 A
- 12V8: 25A
- 12V combined: 110 A / 1320 W
- 12V: 0.5A (6W)
- 5Vsb: 6 A (30 W)
Connections:
- 1 x 20 +4 pin
- 1x 4 +4 pin ATX12V / EPS12V
- 1x 8-pin EPS12V
- 4x 6 +2- pin PCIe
- 4x 6-pin PCIe
- 12x SATA
- 12x 4-Pin Molex
- 4x 4-pin Floppy
Only £233.99 inc VAT.
ORDER NOW
Silverstone SST-ST1200-G Strider Evolution Gold Series - 1200 Watt @ £199.99 inc VAT
To meet the ever higher requirements imbued by professional users and enthusiasts alike, SilverStone created the Strider Gold series power supplies. The Strider Gold models are built on similar platform as the award-winning Strider Plus series but with even higher efficiency ratings.
The Strider Gold series will encompass wattage range from 750W to 1200W for a great variety of applications. In addition to 80 PLUS Gold level efficiency, all models are built to meet very high standards in electrical performance so they have ±3% voltage regulation, ±3% ripple & noise, and high amperage single +12V rail. Other notable features also included are 24/7 40degrees continuous output capability, Japanese capacitors, low-noise 135mm fan, and multiple sets of PCI-E cables. For users looking for a power supply with faultless combination of performance, efficiency, and quality, there is no need to look beyond the Strider Gold Series.
Features:-
- 80 PLUS Gold certification with high efficiency 87%~90% at 20%~100% loading
- 100% modular cables
- 1200W (1300W peak power) 24hour fully continuous power output with 40? operating temperature
- Class-leading single +12V rail with 100A
- Strict ±3% voltage regulation and low ripple & noise
- Japanese main capacitors
- Silent running 135mm fan with 19dBA minimum
- Dual EPS 8pin connectors support
- Multiple PCI-E 8pin and PCI-E 6pin connectors support
- Support ATX 12V 2.3 & EPS 12V
- Active PFC
Specification:-
- Model No. SST-ST1200-G
- Max. DC Output 1200W (Peak 1300W)
- Colour: Black (scratch resistant and lead-free paint)
- Cooling System: Single 135mm silent fan
- Noise Level: 19dBA-36dBA
- Weight: 3.295 kg
- Dimensions: 150 mm (W) x 86 mm (H) x 180 mm (D)
Protection
- Under voltage protection
Connectors
- 1 x 24 / 20-Pin Motherboard connector (550mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector (750mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector (550mm)
- 4 x 8/6-Pin PCIE connector (550mm)
- 4 x 6-Pin PCIE connector (550mm / 150mm)
- 16 x SATA connector (600mm / 150mm / 150mm/150mm)
- 6 x 4-Pin Peripheral connector (600mm / 150mm / 150mm)
- 2 x 4-Pin Floppy connector (600mm / 150mm / 150mm / 150mm)
ORDER NOW
Silverstone Strider Gold Evolution 1000w '80 Plus Gold' Modular Power Supply (ST1000-G) @ £179.99 inc VAT
To make great power supplies even better, SilverStone engineers delved into the details with the Strider Gold series. In order to reduce the already low noise generated by the Strider Gold, they replaced the fan with SilverStone’s own Air Penetrator, which has superb cooling ability and is equipped with fluid dynamic bearing. This allowed for reprogramming of the fan controller to enable lower fan speed at any given loading condition compared to the predecessor. Various components were also re-tested and replaced with newer versions for minor boost in efficiency and performance. An excellent FF141 fan filter with magnets is even included in the package for use to reduce dust buildup.
With the fan and component upgrades, the Strider Gold Evolution series will again encompass wattage range from 750W to 1200W with 80 PLUS Gold level efficiency, ±3% voltage regulation, ±3% ripple & noise, and high amperage single +12V rail as its main features. For discerning users looking to get a top-notch power supply with all features covered and more, this is the perfect solution.
- 80 PLUS Gold certification with high efficiency 88%~91% at 20%~100% loading
- Ultra silent 139mm Air Penetrator fan with fluid dynamic bearing
- FF141 magnetized fan filter included
-1000W (1100W peak power) 24hour fully continuous power output with 40? operating temperature
- Class-leading single +12V rail with 83A
- Dual EPS 8pin with multiple PCI-E 8pin and PCI-E 6pin connectors support
- PFC: Active PFC.(PF>0.95 at Full Load)
- Efficiency: 88%~91% at 20%~100% loading
- MTBF: 100,000 hours at 25°C(at Full Load)
- Operating temperature: 0°C ~ 40°C
- Protection: Over Current Protection / Over Power Protection / Over Voltage Protection / Over Temperature Protection / Under voltage protection / Short Circuit Protection / No Load Protection
- Connectors: 1 x 24 / 20-Pin Motherboard connector (550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector (750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector (550mm) / 4 x 8/6-Pin PCIE connector (550mm) / 2 x 6-Pin PCIE connector (550mm / 150mm) / 8 x SATA connector (600mm / 150mm / 150mm/150mm) / 6 x 4-Pin Peripheral connector (600mm / 150mm / 150mm) / 2 x 4-Pin Floppy connector (600mm / 150mm / 150mm / 150mm)
- Cooling System: Ultra silent 139mm Air Penetrator fan with fluid dynamic bearing
- Noise Level: 17dBA-28dBA
- Dimension: 150 mm (W) x 86 mm (H) x 180 mm (D)
- Weight: 3.255 kg
- Certification: 80 PLUS Gold
ORDER NOW
Silverstone Strider Plus 1000W Modular '80 Plus Silver' Power Supply (SST-ST1000-P) @ £139.99 inc VAT
The Strider series, as the oldest and most versatile power supply line from SilverStone, has models with myriad of innovative features and rating from 350W all the way up to 1500W. To build on this impressive lineup, SilverStone engineered a new generation of power supplies that combine more important features than ever before. The Strider Plus models, ST75F-P, ST85F-P, and ST1000-P are highly efficient (80 PLUS Silver level), compact enough to fit in nearly any system (160mm depth), have tightly regulated performance of ±3% from a single +12V rail design, and equipped with a quiet but cool 135mm fan. To top these features off, the power supplies also come with 100% modular cables with all the important connectors to support current and future graphics card specifications. For enthusiasts that are looking for a power supply with all the right features to make a high performing and aesthetically pleasing system, any one of the Strider Plus models will fulfill the task with maximum satisfaction.
Specification:-
- 1000W 24hour continuous power output with 40 degree operating temperature
- 1100W peak power
- Efficiency 85%~88% at 20%~100% loading
- Class-leading single +12V rail with 80A (peak 85A)
- Four PCI-E 8pin and six PCI-E 6pin connectors support
- Active PFC
- Combined +12V: 960W/80A(Peak 85A)
- Input Voltage: 90V~264V
- Input Frequency Range: 47Hz~63Hz
- Active PFC(PF>0.95 at full load)
- Efficiency: 85%~88%(20% to 100% loading)
- MTBF: 100,000 hours at 25°C, full load
- Protection: Over current protection / Over power protection / Over voltage protection / Under voltage protection / Over temperature protection / Short circuit protection / No load protection
- Connectors: 1 x 24 / 20-Pin motherboard connector(550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(550mm) / 4 x 8/6-Pin PCIE connector(550mm) / 2 x 6-Pin PCIE connector(550mm / 150mm) / 6 x SATA connector(500mm / 250mm / 250mm) / 6 x 4-Pin Peripheral connector (500mm / 250mm / 250mm) / 2 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
Only £139.99 inc VAT.
ORDER NOW
Silverstone Strider Gold Evolution 850w 80 Plus Gold Modular Power Supply (ST85F-G) @ £146.99 inc VAT
To make great power supplies even better, SilverStone engineers delved into the details with the Strider Gold series. In order to reduce the already low noise generated by the Strider Gold, they replaced the fan with SilverStone’s own Air Penetrator , which has superb cooling ability and is equipped with fluid dynamic bearing. This allowed for reprogramming of the fan controller to enable lower fan speed at any given loading condition compared to the predecessor. Various components were also re-tested and replaced with newer versions for minor boost in efficiency and performance. An excellent FF141 fan filter with magnets is even included in the package for use to reduce dust buildup.
- 850W (950W peak power) 24hour fully continuous power output with 40? operating temperature
- Class-leading single +12V rail with 70A
- Connectors: 1 x 24 / 20-Pin Motherboard connector (550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector (750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector (550mm) / 2 x 8/6-Pin PCIE connector (550mm) / 2 x 6-Pin PCIE connector (550mm) / 8 x SATA connector (600mm / 150mm / 150mm/150mm) / 6 x 4-Pin Peripheral connector (600mm / 150mm / 150mm) / 2 x 4-Pin Floppy connector (600mm / 150mm / 150mm / 150mm)
- Color: Black (scratch resistant and lead-free paint)
- Weight: 3.085 kg
Only £146.99 inc VAT.
ORDER NOW
Silverstone Strider Plus 850W Modular '80 Plus Silver' Power Supply (SST-ST85F-P) @ £124.99 inc VAT
- 80 PLUS Silver
- 850W 24hour continuous power output with 40?operating temperature
- 950W peak power
- Class-leading single +12V rail with 67A (peak 72A)
- Dual PCI-E 8pin and four PCI-E 6pin connectors support
- Active PFCcombined +12V: 804W/67A(Peak 72A)
- Connectors: 1 x 24 / 20-Pin motherboard connector(550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(550mm) / 2 x 8/6-Pin PCIE connector(550mm) / 2 x 6-Pin PCIE connector(550mm) / 6 x SATA connector(500mm / 250mm / 250mm) / 6 x 4-Pin Peripheral connector (500mm / 250mm / 250mm) / 2 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
- Colour: Black (Lead-Free Paint)
- Cooling System: Silent 135mm fan
- Dimensions: 150 mm (W) x 86 mm (H) x 160 mm (D)
- Weight: 2.9 kg
Only £124.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - White (NESF-013) @ £209.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Platinum Certified, 91.07% 92.44% 90.47% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specification:-
- Type: ATX
- Maximum Power: 1200W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black (NESF-012) @ £209.99 inc VAT
Features:-
Specification:-
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White (NESF-011) @ £167.99 inc VAT
Features
- 80 PLUS ® Platinum Certified, 91.12% 92.53% 91.11% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type ATX
- Maximum Power 1000W
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- Modular Cable Yes 100% modular cable design
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black (NESF-010) @ £167.99 inc VAT
Features
Specification:-
- Type ATX
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- Warranty: 5yr
ORDER NOW
OcUK is now the KING of power supplies with not only the largest range online in the UK, but we also have the best range of Power Supplies HELD IN STOCK too. :)
Not that mining BTC on 'normal' hardware is anywhere near still profitable anymore...
Yes it is. Vastly profitable.
A friend of mine paid of his mortgage this week and purchased 20pc of HD 7990 from us, I think he disagrees. :)
No it isn't.
Not with the release of ASIC units and the increase in difficulty associated with that.
A machine with 4x 290's in it can process nearly 2 Lightcoins today, at current pricing that is $80 a day.
My mate who is doing this has his entire garage filled with such rigs with HD 7970's, HD 7990's and R9 290's, he has made over £100,000 from it even with electric cost incorporated and continuing to do so, his profit is down due to difficulty levels but he is still making a considerable profit, so he strongly disagrees with you. :)
I was just about to come and edit my post, you're correct mining something else and converting it to BTC can still be profitable I was coming from a mining BTC only point of view.
I wish i had the funds to set this up :)
I really need to find a decent noob mining guide and put my 290 to work!
Only with very cheap/free power is gpu mining profitable.
Ask any of them over in the Distributed Computing Projects section... You need to go into it in a BIG way with some way of running the rigs with very cheap/free power to turn any kind of profit (which includes covering your hardware costs).
There's another difficulty rise coming soon - too much (overdue) recent publicity of BTC prices...
My mate who is doing this has his entire garage filled with such rigs with HD 7970's, HD 7990's and R9 290's......
Hope you gave him "mates rates" :p
Seriously though, I don't get this bitmining thing...read about it, didn't quite understand it...gave up on it. However £100, 000 I do understand :eek: damn wish I had paid more attention to it now...lol
Did "your mate" nab my clearance 7950 too :(:mad::mad:.....git....was there, checked out, 2 days later I get the email....it is now mysteriously "on back-order" .....to be found in a garage near Stoke per chance ?
No we just filled his boot with many HD 7990's. :D
He is now eyeing up our 290 stocks, greedy git. :eek:
