Shortcut to folder contents on desktop
22 Oct 2005
Moving...
I like to save a few files/folders to the desktop when I work. These are usually temporary and only last for a few days, and the turnover can be quite high. The reason for saving to the desktop is I can always see it when I work, and I can access everything with a single click.
Changes are being made to my work machine which means stuff on the desktop will no longer be backed up, so I have to save things elsewhere.
I know I could just place a shortcut to My Docs (or wherever) on my desktop, but that's an extra click and a new window to navigate (I know, first world problems right?!). I could create individual shortcuts to each file in the new location, but as I mentioned, the turnover is quite high so this would be tedious.
Is there something I can do which essentially shows every file/folder from a specific location on the desktop?
Make a folder on your c drive or where ever you want it then right click it select copy then go to you desktop right click it and select paste shortcut, all done!
Sorry I never read your op so ignore me !
Pin them to your File Explorer taskbar icon. Most convenient and available all the time.
