Figured what was causing some discomfort from my Hero chair, and realized by default it sits quite a bit higher than what I'm used too ( causing the back of my legs where they "hang" a little to ache after some time.
Question is, if say I buy the
EXTRA SHORT GAS LIFT REPLACEMENT (-30MM)
https://www.overclockers.co.uk/noblechairs-extra-short-gas-lift-replacement-30mm-gc-01h-nc.html
Does this still have a 10cm up down travel in it?
I'm assuming the -30mm is with the gas lift at its lowest setting, so will it still travel "up" up 10cm?
