I wouldn't even go that far!semi-pro waster said:The cheapest one that OcUK still sells new that I know of is the Asus EN7300GS and that comes in at ~£45.
You might be able to pick up a fairly decent card from the 6800 series or X800series secondhand for around your budget though.
FunkyT said:256MB video is recommended for Windows Vista Aero tbh.
VeNT said:I wouldn't even go that far!
non gaming PC?
x300?
why 256Mb Vmem if you're not going to use it!
the reason that the biggest graphics chip manufacturer in the world is intelsemi-pro waster said:Personally, nor would I but then it isn't my choice here that matters. For ordinary office-style usage integrated graphics is perfectly fine.![]()
Not sure about that. My friend's system with Radeon 9600 Pro 128MB + 512mb system ram was struggling in Aero interface but after upgraded to 2 GB, it is lightening fast! He was joking about windows popping up before even lifting your finger off mouse button!FunkyT said:256MB video is recommended for Windows Vista Aero tbh.
