Should I be concerned?
1 Jan 2006
South East London
After running HDtach and HDtune on a very very old 40GB IDE Seagate I noticed this.
Should I be concerned, what does the yellow thing mean, is the drive going to fail?
I also run SMART and occasionally I get these kind of errors but they usually go away.
It is usually the seek error rate section that comes up on my hard drive.
I would only be concerned if the same SMART error came up every time.
Have you run the Seagate hard drive diagnostic tool to check for hard drive problems?
