Should i be getting these temps?!
13 May 2007
West Yorkshire, UK
ok....
brief explenation im hitting 44 idle and 58 pon load :eek:
this is with an E6600 at stock temps
i had the same with the stock cooler went to a scythe infinity...got the same maybe idle about 39 if my room was uhm cold lol now im with the Arctic Freezer 7 PRO n im hitting 44 idle :(
ive had 2 motherboard with this chip already
first was an Asus P5B which was horrible i couldnt overclock *** so ever :( the stock cooler and infinity was both used with this board
now i use an Gigabyte P35C-DSR3 and this is when ive started using the arctic freezer 7 pro
ive seated it twice i use Arctic Silver 5 as i have with all my coolers my mate uses the exact paste exact cooler n gets 28 temps so what am i doing wrong? :(
he uses the Evga 680i however with a nice north bridge cooler, i gently touched mine n found it was running rather toasty though im guessing these all do....
its rather close to the cooler and am realy thinking this is the problem :(
i was going to go watercooling but dont have the funds sadly
so does anyone recommend any method? or do you think i just got a hot chip? :(
these temps are crazy for a core 2 dup im sure most of u will agree
EDIT:
here's a screenie, if anyoen see's anything out of the ordinary gime a shout please!
my cpu was in thingy mode so it slipped down to 1.6 :D
im thinking it could be the case i use the Thermaltake Shark which is completely open on the side with a meshy thing instead of perspex could this be my problem?
i play a lot of CSS n played it in windowed mode saw the temps hit around 52 never went above that this was in a 20 man server with a bit of action (sound like jacob billing :/)
well the mesh im guessing isnt helping as its probs keeping it at room temp wen i play css n things tho it only bumps it upto like 52 im not worried or anything that int a bad temp not bad bad anyways just for c2d its very unusual
/Grammar Nazi
Anytime you want to use punctuation, that would be good ;)
\Grammar Nazi
Sorry I couldn't resist :( I was thinking of something Toby said in the West Wing :(
To give a slightly more helpful response though -
I wouldn't be really worried about the temps until the mid 60's. I am pretty sure thats the point where most people start to worry for C2D CPU's :)
