Should I be running Vista in Standard Mode?
18 Oct 2002
Kent
I was just reading another thread and someone mentioned that running your PC in Admin mode is an unnecessary risk. I've been running Vista Home Basic 64bit for a few months now and not had any problems and i'm just wondering if i should still really be in Standard mode?
If i create another account will I not have to somehow transfers all my files and install applications to the new account?
Thanks.
I've always run as admin on all my XP and Vista installations without a problem. But if you have a ruck of 'novice' users on your PC maybe consider going down the standard user route.
Prediction: this thread will run and run.....
I always run as administrator on my pc's. Nobody else but me ever uses them so it's never caused a problem.
Ok so if I create a second login am i going to have to reinstall all my applications and games and whatnot?
Oh dear....
*Waits for Fire Wizard*
Hah!
With Vista it is a bit of a grey area. You run as a standard user anyway and when you need to escalate to admin level you get a UAC prompt - this is the whole point. If you are the one and only user of that machine you won't see much benefit from having to put your password in each time you get a UAC prompt.
Running as a standard user is completely normal for pretty much every other operating system out there. It's only because pre-Vista Windows dumps you in an administrator account by default and nobody bothers/knows any better that we have this culture of thinking running and browsing the web as administrator is normal.
I've never bothered running as a standard account and never had any problems because of it but I'm sure Fire Wizard will come along and tell me how wrong this is... :p
You should run either as a standard user, or as 'admin' with UAC enabled. Full admin access is roughly equivilent to an old victorian mill with no handrails and uncovered trap doors, relying solely on the user to never make a mistake or have an accident (such as being effected by a zero day exploit).
Since i switched to standard mode i cant seem to do ANYTHING in C:\Program Files (x86).
Which is a bit annoying really as I move and edit and save files a lot in there.
Not sure why you're doing lots of edits in there, but anyhow, I would switch back to protected administrator if this is the case.
