Good idea, I thought that would come in handy myself for that purpose, does yours fit in the FDD bay or optical?markyb said:I use my fan controller all the time. As my PC is in the front room I use it to slow down all the fans while im surfing the net, when im gaming they all go up.
The fan controller you have posted fits in a floppy disc bay, however you can also get the optical drive bay ones too.
Floppy.mishima said:Do these things fit in the floppy drive bay or optical drive bay?
mishima said:Good idea, I thought that would come in handy myself for that purpose, does yours fit in the FDD bay or optical?
mishima said:Thinking about getting an AKASA AK-FC-06-BK Black 3.5" Fan Controller. Should I get one? It's only going to cost me buttons but I'm unsure whether to get one or not, do you use one?
Is a very nice controllermarkyb said:
I have it tooI thought it would be a nice addtion when I come to overclock in the next few days, and whilst gaming I could put the fans on high etc. If I have a fan that operates @ 1200RPM, what will the high and low setting be for this fan?MT01XP said:Do you have the need to vary the speed of your fans?
i know how to set all the options etc, but where on earth do you plug the wires in on the motherboard??? (obv this all depends on the motherboard.. i have the BFG 680i - is it possible to plug it in on this one?)furnace said:Is a very nice controllerI have it too
V|per said:Sorry if this feels like im ripping the thread here, but i also have the optical bay akasa 4 fan controller.. i can't figure out how on earth to get it monitoring tempsi know how to set all the options etc, but where on earth do you plug the wires in on the motherboard??? (obv this all depends on the motherboard.. i have the BFG 680i - is it possible to plug it in on this one?)
Cheers,
Phil
markyb said:Temp Wires![]()
The temprature wires coming out of the fan controller are temprature probes. You have to place these either on the heatsink or the core of the chip you are monitoring.
Personally ive just used one to monitor the case temp which gives me a indication of the heat inside the PC.
