Should I get a new food processor or a hand blender with food processor attachments?
1 Sep 2003
US of A
Hi,
I am starting to eat gluten-free and a lot of the recipes require things like blended cauliflower. I don't have a food processor or hand blender with food processor attachments yet, and am wondering which one I should get.
If you were in my position, which would you get? Do people find hand blender food processor attachments adequate for light processing use?
Whatever I buy, I need to get it from John Lewis as I have been given several hundred pounds of gift vouchers for the store.
Thanks,
Jon
Either would do the job, a food processor would give you more flexibility.
The secret to nice smooth purees is always blitz it while it is hot otherwise it goes grainy.
How interesting. Can you give us a little more info on your diet and some of these recipes, please?
Absolutely so.
My Magimix doesn't see much use for the sort of processing you seem intent on - I'd be buying one of these if I were in your position.
My brother and sister-in-law eat a paleo, gluten-free, low carb diet (in the USA, which is *significantly* easier than in the UK) and eat things like: http://genaw.com/lowcarb/faux_rice.html
I would get a food processor it will do the job properly.
Which one would you get? Magimix? The reviews on Amazon UK seem mixed, due to the triple bowl design. Some say that food spills into other bowls when using the smaller bowls.
Oh, you said blended - for something grated like that you're really going to only get any joy from a food processor.
They must be doing something wrong then.
Each bowl has it's own specific uses - if you're stacking them to use the smaller ones and food is spilling over, it's being overfilled or being used for the wrong purpose.
Sure, would you recommend a Magimix then? If so, what size would you recommend for a single guy like me?
Thanks.
I've got a 3200 and it's big enough to handle processing food for feeding up to four people - some things can be a push, but you can always just do another batch.
The 3200XL might be worth looking at for you, due to the increased size of the feeder nozzle. Would probably make life easier and is the one thing my 3200 can struggle with when I'm making slaws and suchlike with the grating discs.
I would probably buy something cheap and simple like this to be honest.
http://www.amazon.co.uk/Kenwood-FPP...UTF8&qid=1388848982&sr=1-2#productDescription
It has a reversable grating disc/cutting disc a beater and a blade and can be used as a liquidiser. \it hasn't got a load of attachmenst you won't use and looks nice and compact. It's cheap enough that if in 6 months you find you need a more sophisticated machine you won't mind the addiional cost.
Sounds good, thanks! I would ideally like to buy a Breville Sous Chef Food Processor (http://www.amazon.com/gp/product/B005I6ZKCE/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER) but they're only available in USA and the import fees would cost a fortune if I was to order it to be shipped to the UK. I might be moving to the US later this year anyway so I might just buy this one to tide me over for now.
I'm going to bet the OP has eyes firmly fixed on a Magimix, ...
No, not really. :)
Marketed as the Kitchen Wizz Pro by Sage in the UK, if you're really that keen.
Ah, interesting. I hadn't realised that, apologies. I'm not sure that I really need something so big for now, and would prefer to get it in USA if I was to move there. I'll give definite consideration to a cheaper Kenwood for now.
Thanks again for your help.
... something like this would be a better short-term investment. ...
Alas, it's out of stock at John Lewis. I might get something similar from Amazon instead.
I've got a kmix mixer with a bunch of attachments - the rotary cutter attachment is pro for making cauliflower "rice". I've used it for this purpose a few times now.
I've previously used a regular food processor to make it, but it's very hard to get the cauliflower the right size - it often ended up too finely chopped, meaning the "rice" ended up mushy. With the Kmix roto attachment, it's always the same and always perfect :)
I find I use hand blender more often than food processor, although really need both. I need a new hand blender as the chopping blade has vanished off the face of the planet :(
A hand blender with the bowl/chopper blade makes something very much like cauliflower cous cous. So you dint absolutely need a processor. Hand blender is also better at making purée. Especially if its small amounts.
