Should I put this order in. HELP
3 Dec 2004
Hi all,
As some of you may be aware, ive been considering upgrading my 9800PRO to a 6800GT (AGP), Thanks for all the great advice.
However, im thinking I should just get a PCI system (meaning new board + vid card). Is this likely to be the best value for money I will get:
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO) 1
£136.95 £136.95
MB-000-AK Asrock 939SLI32-eSATA2 (Socket 939 & Upgradable to AM2) PCI-Express Motherboard (MB-000-AK) 1
£49.95 £49.95
Subtotal £186.90
VAT £32.71
Total £219.61
I will use my existing 3000+ with XP120 HS/F. 3200 ballistix ram (512) PSU. Raptor and sell my abit AV8 + 9800PRO.
What do you think guys? I really want to upgrade now :)
GhostRider said:
ATX version 2 powers supply 580 watts or more.
:( I have this:
Tagan TG420-U01 420W ATX2.0 Silent PSU (CA-002-TG)
If I have to get a new PSU then I will have to leave it and put up with my current system.
Its recommended in this sticky http://forums.overclockers.co.uk/sh...ad.php?t=121317 that you have one
PREPARE YOUR SYSTEM
Its not uncommon these days to require a good quality PSU (Power Supply Unit) . To achieve maximum compatability it is recommended to have atleast a quality 350+ Watt PSU.
My personal findings show that the Enermax 350w+, Antec TrueBlue 480w, Hiper Type R 580w all work without problems on anything less than an X1800XT . For an X1800XT or X1900XT(X) GPU i would recommend a minimum of 580w
I have no experience if this is actually the case tho
I hope it will be OK.
Do you think its worth spending the extra on a Asrock SLI32 board even though I would be getting an ATI? I think i read somewhere that the sli can run crossfire with driver hacks - is that right?
Is the SLI board faster then the AGP model due to it being newier?
Regards
SLi is faster than AGP anyways mate.
If you are running a single graphics card then you may aswell just look for a board that doensn't do SLi/Crossfire as you will not be needing it. If you're an overclocker then you can't avoid getting an SLi/Crossfire board that easily.
I'd also say you need some more RAM, 512mb RAM these days is nothing really, even just for windows apps.
I'm guessing you are a gamer hence the X1800XT in which case you'll notice a lot more of an improvment in your computer if you get 1GB+ of RAM.
InvG
InvG
Hi,
I chose the Asrock as its cheap - and seems like a popular choice. But there are 3 models available. I would only be using 1 card but for only 10 quid extra wont it be better to get the SLI32 model (can it be used for corss-fire??) for future upgrades.
Please get back to me :)
Regards,
I was under the impression there was a driver hack or something allowing crossfire?
Regardless, would it be better just to get the SLI board for future? I waont have any probs running 1 ATI card anyway will I?
They both have a 16 speed PCI-E slot so the cheap one will be just as fast the SLI one if you only put one card in. Had a quick look and can't see anything about converting SLI to crossfire :(
GhostRider said:
Yeah that looks like the best deal for you, as long as you have a 939 chip and an ATX version 2 powers supply 580 watts or more.
Jesus, I run a x2 7800gt 2gb ram and 5 drives soundcard 2 fans of a 400w PSU....
You 580w comment is only true of cheap PSU's. :)
580w is completel overkill, his current PSU would be sufficent!
Go for it, it's a great upgrade. It should work just fine with your PSU, Tagans are great. I have that card, and it's great also, good luck!
Only thing I might change would be the motherboard to an ASUS A8N5X. Not that the ASROCK is a bad board, but because I'd always feel more comfortable using ASUS or DFI (the best two mobo companies IMHO). Plus, it's £5 cheaper!
Gotta emphasise this, you really need at least 1GB of RAM, I wouldn't be surprised if some of your performance issues are down to this rather than the GPU :eek:
Will order some more RAM too then - is it best to get another crucial ballistix 512mb PC3200 or will any brand do. Will I beable to run dual channel?
Also, has asrock got an offcial support forum?
