I have a new build with a 5900x and Dark Rock Pro 4 in a Lian Li Lancool II mesh.
If I gradually increase the load on the CPU I hear the fans ramp up (both fans on the Dark Rock and all case fans tied to CPU temp - I use 60C as the trigger temp in this case). However, with no change in the load the temperature does not decrease at all. Neither does it increase. I would have expected the temperature to drop a little as as the fans shifted more air. Is this a correct assumption? I started to wonder if I fitted the middle fan of the cooler the wrong way round so it is fighting the main fan air flow, but temps do not get excessive so not investigated further - yet.
If I decide to remove the cooler to check it out I want to replace it with the best thermal paste for the job so any recommendations there would be gratefully received, especially from people with the same components. However, I don't trust myself with liquid metal types.
