Your arguements are invalid because tyres!
I was thinking about this on the way to work this morning, if the brakes on the car are good enough to lock up your wheels/ engage ABS under heavy braking then upgrading your brakes would be pointless for road use as you're not going to be able to stop any quicker. Track use though would be definate upgrade, probably worth upgrading if the powertrain is stock due to overheating and fade.
As for the B road blast, more power means higher speed achieved before braking i don't think it would have too much of an effect. If the speed limit is, for example, 60mph then the only time that this would have an effect is where the braking points are close enough together that you cannot hit the speed limiy of 60mph. So unless you go from moderate power to monster power the speed differential at those braking points between stock and modified isn't going to be huge therefore extra braking force isn't going to be greatly different.
Edit: This is ofcourse assuming that speed limits are not broken. However those who would in a modified car are likely to in a standard one too so really rules the poit a little moot.
In summary I think the best answer is you don't NEED to but is probably a very very good idea to upgrade them too. As said above balance is what you should aim for.
