Slightly odd one this, we are looking to put a bathroom into a small bedroom and the best place for the shower to be results in it being partially in an alcove next to a chimney. What we would like to do is position the shower tray across the full width of the alcove and then use a two sided shower enclosure for the rest. If you look at the following picture the walls a re black shower tray red and enclosure green
![](https://i.ibb.co/yX1FV79/Shower-cubicle.jpg)
The challenge as I see it is getting enough of an overlap on the tray to attach the encolsure to as it comes out of the alcove. The alcove is wider than the proposed shower tray so my thought is to put a a solid timer at the corner with as much over lap on the tray as possible and board and tile over that which should potentially allow the mounting of shower encolsure by screwing into that timber. Does that sound sensible? has anyone seen it or done it as I can't fin anything online!
