Shutdown / Restart Problem
14 Nov 2006
Right another problem if i want to shutdown / Restart my PC i have to press the button twice in start menu. The first time just shuts down a few programs the second does the required tasks. Whats causing this Thanks.
your sig is too big 4 lines max m8
click start then run
type msconfig go to the startup tab and disable everything u dont need ( i disable everything) click apply and ok
it will ask you to restart once you have restarted click the box and ok then try shutting down
goodluck
