(Not sure this is the right forum - please move mods if its not).
I've brought an SN25P from OCUK and today got the rest of the parts for it also from OCUK, which for info are:
AMD 64 X2 Athlon 4400
2 gig of Ram
OcUK Galaxy GeForce 7900 GS
SATA HD
DVD RW
I followed the instructions and put them all into the case and turned it on. Very little happened. It wouldn't even show the BIOS. The GCards bios would show up on screen (you know the bit that says what it is etc etc), but then it would just reset and do the same thing again.
Can anyone offer any help as to whats happened? I have built systems before and was carefull when handling the parts. The SATA HD has no jumper on it, should it? I've never used a SATA HD before.
Anyhelp would be great.
2 gig of Ram
SATA HD
DVD RW
