Uh, the XP-120 is better than the SI-120, and the XP-120 is more or less on par with the Big Typhoon.nick_lerwill said:but whats better the si-120 or the big typhoon
so from what people have said the XP-120nick_lerwill said:but whats better the si-120 or the big typhoon
ted34 said:The big typhoon should outperform the xp120 depending on fans used but if the same fan was used then the BT should be better. Depending on case airflow you may be better off with a ninja than the BT. I just upgraded my xp120 to a ninja
No, it's notlay-z-boy said:si-120 is slightly better than xp-120 but the si is != tt bt
so imo, if you can, get the big typhoon.
You can't really say, because you could get a fan with more airflow than the one on the BT has, which will outperform it. Or you could get a 120mm fan with poor airflow in the XP-120 which would mean the BT whoops it. I think probably the BT is maybe slightly better as a heatsink.bbreezeuk said:which is the best cooler out of the TT BT the SI or XP 120s
the best quitest/performace ratio with a 7volted akasa LED fanA random name said:You can't really say, because you could get a fan with more airflow than the one on the BT has, which will outperform it. Or you could get a 120mm fan with poor airflow in the XP-120 which would mean the BT whoops it. I think probably the BT is maybe slightly better as a heatsink.
no because they are to hard to get hold of and they dont have LEDs which is waht i wantVaderDSL said:Get yourself a Panaflo L1a 120mm fan and 7v mod it, quieter than the Akasa ambers and pushed more air and probably at a higher pressure too.
Or you could do what i did and get the M1A fan and use a fan controller to get it down a bit in speed. It's really quiet but still pushes a lot of airVaderDSL said:Get yourself a Panaflo L1a 120mm fan and 7v mod it, quieter than the Akasa ambers and pushed more air and probably at a higher pressure too.
A random name said:Or you could do what i did and get the M1A fan and use a fan controller to get it down a bit in speed. It's really quiet but still pushes a lot of air![]()
bbreezeuk said:no because they are to hard to get hold of and they dont have LEDs which is waht i want
