Side fans?
Status
Not open for further replies.
Blowing onto the GPU is best to push the hot air away from it. The cases normal top / rear fans are all you need for exhaust.
Thanks, just saw this video and the dude said it was exhausting the heat away from the gpu.
Was just worried, as on my 800D I had ALL the fan sucking/blowing air into the case. And I couldn't work out why it was so hot for a silly cd2 setup lol But 800D is poor for air, good for h20 :D
you are proberly best putting a filter on that side as well to keep dust out
have the same case and keep thinking about the side but dont have issue with gpu heat so have left mine open and the holes pick up a lot of dust from the air being sucked in from the exhausts
Status
