- 17 Jan 2006
No problem mounting post on wall.
I had a similar problem a few years ago, solved by sleeving a water pipe, with a piece of plastic 40mm waste pipe, cutting it along it's length so you can slot it over pipe, then make up some form work either end of pipe & filled space with concrete, to provide base for a pier.
You could scrape about a bit and see if you can find the top of the pipe in the border bit then if you get low enough cast some concrete for a pier, if you find it think of something else.
The pipe should be 400 - 600mm deep ha ha
I was actually more thinking if it was ok to do but both of these seem like great plans and I'm guessing I can just do this then build a nice brick pillar to hold my gate
