Side Window Question?
26 Jan 2007
Leicester/The Toon
Hey,
I already have 1x 90mm Fan, on the window of my PC Case. But I want to add another one, do you know what I could use for to make a new hole?
- Matt
Hole saws. Fits into a power drill and just drill through the window. Mask the whole area off as it helps prevent splintering and gives the drill something to bite into. No doubt someone will give some other advice. Probably better off converting it to a 120mm fan instead though.
