Sig Guru's please apply !!
1 Oct 2004
Rowley Regis, West Mids
Hi all EYEREX done this amazing sig for me a couple of years ago but I was wondering if anyone could mod it for me, I would like a pic of my car added to the sig somehow.
Pic1
Pic2
Pic3
I qiete like pic1 & pic2
I'm far from a guru but here's a few quick ones:
Hey Platypus that second one is very nice can you add test on the bottom somewhere (2005 Vivid Blue Pearl EP2), O prefer the 2nd one because you can see the car clearer but you cant really see my name ? would anyone else like to have a go.
Is something like that ok just needs the text
update with text
Looks better with just a honda badge :)
update with text
They look Class, I have found another pic of my dog can you use this one istead of the pic on the right.
I really like the 4th one with just the badge but would there be away of putting the car in the background faded aswell like platypus did on hes second sig ?
What about that :)
Oh man that looks sweeeeet, any chance of just zooming out on the background a bit just so you can see it a bit more just wanted to see if it would look any better
Tyra is spelt wrong too mate and there is a blue background that looks a bit odd, but keep up the brill work
Will have a play later and try to get a bit more of the japanese bit to show and didn't see the spelling mistake :)
reason it's on a blue background as it makes it easier to do the pop out bit as file is to big for site if saves as png
when done will do a normal png so can be used on other sites without problem :)
Yeah cheers mate if you could do a version without popup, a version with popup with white background and one with blue that would be brill
I have always wanted a Red Staffy, ones I know have all been brindled or white/brindle; are they any good with little kids, heard mixed reviews! (Have a little niece - 18 months old)
