- 12 Jun 2006
I'm on my second set of ballistix and they are failing again..
...my problem is i run mem test at the rated specs of 250mhz 3-4-4-8 2t 2.8v and it passes without 1 error but i try using my pc at slower speeds (200mhz) with same voltage and timings and i get no end of BSODs. with other RAM it works fine.
Does anyone know how Crucial actually test the sticks? do they simple use memtest or do they do other tests?
thanks in advance
thanks in advance
Buy some Corsair or G Skill or sommet
