Sigma 100-300mm F4 - Tripod question
18 Oct 2002
Leamington Spa / Oxford
Now that i'm edging closer to buying a Sigma 100-300mm F4, i'm wondering about how exactly it attaches to a tripod.
Will it just attach to the screw like a camera?
What's best with this lens, to attach the tripod to the camera or to the lens?
Thanks!
I presume, it will have a thing around the lens, which you screw into the tripod, if you screw the tripod into the camera, it wont stay still becauses its long, so i would imagine that there is a connection thing around the lens, which i have forgot the name of.
There is on the 70-200 f/2.8
Dan
There is a lens tripod mount fixed to the back end of the lens and that will accept a screw thread to either go directly onto a mono pod or onto your tripod by screwing the tripod plate into it and then locking it onto your tripod. Unless its a cheaper tripod that only offers a screw also like the monopods.
Dan
a tripod mount ring.
So does the lens come with the collar on the bottom AND a tripod plate?
Or does the tripod screw directly onto the tripod collar on the lens?
My tripod in a Manfrotto 724B with a Ball head.
If its the 100-300 F4 then yes it comes with the ring and a hood (nice sigma)
It wont come with a tripod plate. That is something that your tripod would have come with.
If the tripod doesnt support a plate then yes its as simple as screwing it into the lens ring.
example of plate and ring.
http://img55.imageshack.us/img55/7331/mg93776hp.jpg
