Sigrotor + Coding Help + Mini Project
The index file under /signatures/ needs to exist otherwise it'll throw that nondescript error message as there's nothing to copy.
Also make sure all the defines are correct if you're manually copy the changes.
I will do a rewrite rule variant when I get half an hour, as the current solution is pretty horrible.
ah yes it was down to that file not existing it works! just tested it.
It's a working site now so can be used! :D
https://forums.overclockers.co.uk/threads/sigrotor-is-back-2021.18919999/
