Hi there - not entirely sure where to post this but I thought GD may give the most responses.
For a party, I’ve arranged a silent disco. There will be four different and curated playlists running at the same time, for several hours. These playlists exist on my Apple Music account, where I have access to all of that music. The ‘broadcasting’ device I will be getting requires a headphone input for each channel.
I therefore need four devices that can be loaded with music with head phone inputs, which can easily be used to run the playlists simultaneously. All of these devices would ideally be compatible with Apple Music playlists so that I don’t have to spend an eternity re organising all of the music into or from a different software player.
Also, some the devices will be used to play different playlists at different times of the day, so they need to be very easy to navigate (i.e. with a display). There’s probably 25 hours of music in total.
One solution is to buy four iPod touches and run it all that way… then sell them second hand. That would give me peace of mind. It seems like a very expensive solution though! At the same time, I don’t want to fart around for hours trying to import music and create new playlists again. It feels a little fiendish!!
Any suggestions? Thanks.
