Silent Gpu
16 Dec 2009
I need help finding a silent gpu,
Needs to be:
Silent
Windows 7 compat
play some games like fallout 3 (not on high quality if cant)
Fast booting
dx 11
I noticed some of the silent gpu use 64bit, does that slow them down a lot when comes to gaming? im going from a hd 4670 but its making to much noise for my bedroom when combined with everything plus it doesnt install in windows 7.
haha i should have put i want pay £60 max even if that means used :P
Forget it. If you want all the features you listed your going to have to cough up at least £80 for a Radeon HD 5670 which is a passive card so that meats your criteria for a silent card.
If you can put up with some noise then OCUK do a cheaeper 5670 for £65. You might be able to get away with a 5570 which is in budget (not sure how much silent cards retail for though) if you game at 1280x1024.
A spec me a GPU thread without a budget or a resolution! Classic!
As above what resolution do you game at. This will affect what card you can get away with for running say FO3 on medium detail.
