So your now discrediting you own review site. well done. No it's not a perfect case but its £60 cheaper than the akasa. the sound deadening will lessen any noise, not remove it. you can replace the fans with noctua and still be cheaper than the akasa. Heat is not a problem he not looking for a high end overclocking case.
with such a tight budget and wanting silent it would be mad to go for a case like the akasa, even though it is a brilliant case.
Trouble is ocuk don't do a huge range of budget cases.
I would pick what I have now a Sharkoon Rebel 12 Economy Edition Black £56
+ 3 800rpm noctua. which is basically what I have know.
Or the antec 300 although you would need to change the fans as the tri-fans aren't particularly quite.
or
Silverstone Kublai
or
Silverstone Kublai
