Silent / Quiet PC?
To minimise noise on my tower i decided to go 200mm fans at the front as intakes. Bigger fan lower rpm to push same amount of air.
In your case(no pun intended) you need to investigate your air flow thro the case, and go from there.
I decided to clean out the case as it had been a while.
The AIO cannot be controlled, SATA power is the only connection on the pump, the only thing that can be controlled are the PWM fans. Exhaust and Intake fans on the case are also different so will need to replace those
The only noise coming from the PC at idle is the AIO pump, and that is causing all of the vibrations and noise.
So I am thinking of something like this (I don't need the case, I just want a new one) - and some form of controller for the RGB
My basket at OcUK:
Total: £264.97 (includes delivery: £0.00)​
My basket at OcUK:
very nice case ive had a few and love them, right now i have the O11 vision looks amazing.
the cooler will fit on the back but if you have a long GPU it will touch the fan frames but again it will fit.
if budget allows you want to use all the fan locations thats why the case as good cooling,
I build myself
Cooler Master HAF 500 Mid Tower Case - Black with​
Noctua NH-D15 G2. But then again, i have 5600x and 3070FE. so not much heat. cpu and gpu idles at 40c.​
