Silent , Small HTPC
26 Mar 2010
Hi all,
Looking to build a HTPC which will only be used for downloading movies etc.
Front end will be PLEX or XMBC and I want at least 4TB space with maybe a small boot SSD.
Would like some recommendations? Would prefer a good looking system that can sit under the TV.
Is it possible to build a fanless system with this spec?
Cheers to anyone who can offer any help/pointers...
Hi,
I've just put together an ITX system using a Silverstone ML05. There's enough room for 4 2.5" drives, in fact if you used an external psu then I'm pretty sure you could fit 2 3.5" drives as long as you have enough power.
Size wise, its about as bit as an Xbox. I'll be putting some pictures up over the weekend.
Hi,
Thanks mate - much appreciated
Also, if you're thinking of plex then maybe look into having a NAS host the media and plex server, which will allow you more freedom for the media box.
