Will using a Silentmaxx hard drive enclosure actually make any noticable different to the latest quiet hard drives? (In a water cooled system so not much noise from fans)
What about the ocuk anti-vibration hard drive mounts?
I got 2 of those drives with barracudas in them and then one barracuda case mounted. They help with vibrations mainly but they also act like heatsinks and have lowered my drive temps by about 5-6degrees. The drive thats case mounted i have mounted 90degrees to how it should be and then put it in a sling made of string and thats stopped the vibrations from that drive
has anyone used one of the waterchill hard driver coolers? Am thinking of getting watercooling so thought it might be a good idea to route it around the hard drives.
Would these reduce noise at all or would I be better off with the others?
