Silly PSU question but urgent!
Which is which though, with the switch showing 230 is that set to 230 or does it have to be on the side the 230 is with the 115 showing? if you see what i mean!
It came with the 115 showing and the switch over to the 230 which is why i ask!
As above. Do not think that because the 115 voltage is lower than uk 230V that it will do no harm to your system (in case curiosity got the better of you like it did a friend of mine ;))
Ah i know it has to be on the 230 setting, is this with 230 Showing on the tab, or do you slide it over to the side where the 230 is written when the 115 is showing.
I only ask because the psu came with 115 visable!
Stupid question but rather get it right and switch it over so the 230 is visable before i put it in the pc!
Painful memorys there, wont be doing that again in a hurry :D, luckilly it was only a 2 ghz celeron system (going back about 3/4 years i think) even luckillier it didnt suffer any damage and went on to work fine after buying new psu :p
EDIT: i think these videos will better explain it :D
