Silly UPS question
Baz
Baz
9 Dec 2002
Peterborough
Silly question, but never had to change a UPS battery up to now...
If I keep the UPS turned on at the mains, and remove the battery, will it still supply power to the connected equipment (but of course give no protection?)
</silly mode>
You should be fine then but IIRC the documentation mentioned that it would be OK so double check.
Dont keck yourself when it sparks either :)
I love that part when you connect them up :) especially in a darkened room :cool:
