- 19 Mar 2015
Hi everyone.
After 6 heavily used years, I have decided the time has come to do a full system upgrade built inside my Silver Stone Raven case.
I had toyed with the idea of going for a completely new build but I kind of like the layout of my current case as I can easily access the I.O on my motherboard & it has plenty of room to work in, but perhaps most importantly I need to hide it from the Wife.
I have about 2k to spend which would need to buy a new graphics card, PSU & upgrade bundle, I will probably have a new Monitor, PSU & boot drive as well.
My rig would be used mostly for gaming but also some CAD work which includes some rendering of images.
I got some really good advice via O.C on my last build & thought that I would throw myself on the mercy of the O.C crowd once again.
I really want to get the best bang for my buck & really don't know if Intel or AMD is my best bet so I would love to hear your thoughts.
I will also probably need to update my monitor.
My current Spec is:-
CPU
Intel Core i5 3570K @ 3.40GHz
RAM
8.00GB Dual-Channel DDR3 @ 800MHz (11-11-11-28)
MOBO
Z77-D3H (Intel Core i5-3570K CPU @ 3.40GHz)
Monitor
ASUS VS247 (1920x1080@60Hz)
4096MB ATI AMD Radeon R9 200 Series (MSI)
Storage
223GB OCZ-AGILITY3 (SATA (SSD))
2794GB Seagate ST3000DM001-1CH166 (SATA )
596GB Western Digital WDC WD6400AAKS-22A7B0 (SATA )
Audio
ASUS Xonar DG Audio Device
PSU
OCZMODXSTREAM-PRO 600w
I may consider keeping some components if you think it's worth it.
Cheers in advance.
Bullitt
CPU
RAM
MOBO
Monitor
Storage
Audio
PSU
Cheers in advance.
Bullitt
