Silverstone 1200w Strider '80 Plus Gold' Power Supply - IN STOCK... AND HOLDING THE PRICE TILL FRIDA
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi Guys
We have a big delivery in around 14 days of the Silverstone 1200w Strider 80 Plus Gold Certified 100% Modular PSU.
Our pre-order price is only £149.99 cos we love out customers :)
Get involved!
Silverstone Strider 1200W Modular '80 Plus Gold' Power Supply (SST-ST1200-G) @ £149.99 inc VAT
To meet the ever higher requirements imbued by professional users and enthusiasts alike, SilverStone created the Strider Gold series power supplies. The Strider Gold models are built on similar platform as the award-winning Strider Plus series but with even higher efficiency ratings.
The Strider Gold series will encompass wattage range from 750W to 1200W for a great variety of applications. In addition to 80 PLUS Gold level efficiency, all models are built to meet very high standards in electrical performance so they have ±3% voltage regulation, ±3% ripple & noise, and high amperage single +12V rail. Other notable features also included are 24/7 40 degree continuous output capability, Japanese capacitors, low-noise 135mm fan, and multiple sets of PCI-E cables. For users looking for a power supply with faultless combination of performance, efficiency, and quality, there is no need to look beyond the Strider Gold Series.
- 80 PLUS Gold certification with high efficiency 87%~90% at 20%~100% loading
- 100% modular cables
- 1200W (1300W peak power) 24hour fully continuous power output with 40? operating temperature
- Class-leading single +12V rail with 100A
- Strict ±3% voltage regulation and low ripple & noise
- Japanese main capacitors
- Silent running 135mm fan with 19dBA minimum
- Dual EPS 8pin connectors support
- Multiple PCI-E 8pin and PCI-E 6pin connectors support
- Support ATX 12V 2.3 & EPS 12V
- Active PFC
Only £149.99 inc VAT. -PRE ORDER PRICE!
ORDER NOW
correct, they are wrapped the below photo is an example of the cable wrap. This is the 850w version of this PSU (Cleeeeecooooo - braided means each wire is indivudually wrapped, these are not)
Derp; my bad.
Do you know if the 1200w has those silly metal rings under the sleeve that make braiding it yourself stupidly difficult?
MY 1kw has decided to go pop along with everything else i touch so i'm looking to get one of these.. :D
