I've still got mine although I'm not using it at the moment. I always used to just unscrew the whole filter/fan assembly so that I could slide the filter out. Bit of a pain tbh. I did see this youtube video:
Looks like they cut a chunk out of the side at the top and turned the assembly around so it slides out the side.
Yeah seen that one could you possibly do me a favour if its not to much of a pain to do Jon20 could you measure the top mesh on the outside of the case. Thinking of using magnetic filter on the top.
The mesh on the outside of the case is roughly 180 x 180mm although you would probably need to trim the corners.
Not sure if you have the case yet but if you want front usb 3.0 ports, then do a search for Silverstone G11303500. Not sure if it's still sold, quick google search would suggest you can get it from Germany.
