Silverstone SG05 + WATER COOLING
2 Feb 2008
Rainham - Kent
Hi,
Has anyone attempted to fit a Corsair H50 High-Performance CPU Watercooler in a Silverstone sg05 mini itx case? if so what was it like in such a small case temps wise and did it attach to the front 120mm intake fan ok?. The reason I ask is coz I'm in the process of getting the bits to do a build and just fitted one of thses corsair coolers to a m8's quad core cpu in a much bigger case and was quite impressed with load temps on it for such a cheap little bit of kit.
Cheers
Yes I had already read his post a while ago, just wondered if anyone else had done it with a q6600 or such:D wanted a bit more info on temps
