Sim rig build
13 Mar 2005
Hi all,
Looking to build myself a sim rig. Not built a pc in a fair few years since I switched to Mac so no idea as to where to start.
I only need the base system so motherboard , CPU and cooler , ram and graphics card. I still have a case and SSD from a few years back which will do fine.
For now the pc will be used in my living room so needs to be quiet and it’ll be connected to a 65” 4K tv. I plan on going VR in the future so ideally want a decent GPU to power my current TV at its native res and VR in the future.
I have a budget of about £600. Is the above doable or will I need to up my budget to achieve what I’m after?
Thanks
Hi all,
Thanks
using sale code found here
https://forums.overclockers.co.uk/t...t-7-big-discounts-on-graphics-cards.18810858/
£754
BB CODE
My basket at Overclockers UK:
Total: £936.02 (includes shipping: £11.10)​
bring in budget but just does VR okay and 1080p High 60hz gaming £635 using discount code
Total: £687.02 (includes shipping: £11.10)​
push the top if you can !
Great thanks.
Will the 1060 Setup easily drive my 4k tv with medium to high settings?
Thanks
Nope. 1070/80 might get away with medium and run 20/30 FPS in recent triple AAA
Depends on the games you play, should be able to research and see how they run, but yeah, 1070 at a far stretch and miles better then 1060 at VR!
I can just about run AC in 4k/60FPS but not maxed out
Try and wait, no way I’d be buying a new card at the moment for a number of reasons
